soon... it will all come together soon...
my mate is going to give me his R33 Turbo *arent u danny :)*
then comes the carbon vented bonnet and some wheels... shweet! :) give me 8 more months then i'll stop :)
https://www.sau.com.au/forums/topic/9401--/#findComment-141837
actually i will stop after what i said before and then just buy a GTR... then again i need insurance and will probabnly have to wait to insure a GTR for at least another 3 years...
oh god damn it!
https://www.sau.com.au/forums/topic/9401--/#findComment-141889
hi flow? what a waste of money... if im going to spend 1500 on hi flowing an r33 turbo i might as well just go buy a better aftermarket one like a TD06 which im going to do further down the track anyway
https://www.sau.com.au/forums/topic/9401--/#findComment-142233
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
