With the recent stolen cars around, esp Skylines, and other hi-po cars used in ram raids crimes, is this a bit of a worry?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...item=2401200685
I know maybe the buyer could be a legitimate locksmith, but what if someone who plans to organise a large car pinching operation?
Just a thought...
I checked the eBay again, and the item is no longer there... maybe cancelled by eBay?? Anyhow, I think selling lock picking equipment (particularly for hi-po cars) to general public are a bit dodgy.
The seller said the "lock jiggler" equipment will open japanese cars like Nissan & Toyota INCLUDING Skylines, 180SX, Supra, MR2....
You name it, any performance imports was listed... I hope it never falls into the wrong hand, especially after a few ram raids in NSW and other states involving stolen cars.....
Wouldn't that kind of auction encourage would-be-car-thieves to buy it and try out their skills??? Since if anyone buys anything on eBay, there's no way to track it or to be sure what the buyer's purpose or motives are.
where i used to work at a mechanics, trucks used to come around selling tools. anyhow one day a truck came around with this long metal ruler look like with an anchore thing on the end of it, basically a flat hook going in both directions(like an anchore) and this was for breaking into cars. One of the guys bought it and tested it out on a taxi which we were fixing and yep! enough said, these have been around for a long time..im not sure how they can get away with making and selling them?
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
