Regency is the suburb that the motor vehicle testing place is. If you bring an import or a car from another state into SA and want it to be registered in SA than you have to take it to the workshops in regency for a compliance inspection. Remeber that they don't transfer your remainibng rego from state to state so if you have moved here don't bother changing to SA rego untill your old rego is about to run out. Hope that answers your question steve.
Steve,
I'm sorry to say but it sure will :)
"Regency" is the term commonly used for the Regency Park (suburb) Vehicle Inspection Station. It's the place to get defects cleared, import compliance checks, & most important to you, rego transfers (WA to SA).
I had to go through a basic Vehicle Identification Inspection (VII)when I transferred from NSW to SA. You can only remain on WA rego for a small time period (can't remember how long?). My NSW rego was due & I could've just renewed it but as NSW requires a road worthy inspection anyway I needed Transport SA to sign off on it!
I rang & asked Trans SA & they said I MUST transfer to SA, even though I'm in the Defence Force & "should" be able to remain registered in whatever state I choose! Anyway I bit the bullet & got it done ;)
You only need a VII not a full roadworthy (much bigger - nasty!) but they'll still pick you up for obvious no-no's. The purpose of the VII is to ensure the car is legally registered to you & complied within Australia. They check the VIN & Eng #'s (engine # is stamped on the block low down LHS).
As a rough guide here's what I did/didn't have a hassle with:
*Failed*
MOMO Race wheel - didn't comply with ADR's. It did! They were full of B/S but I wasn't going to fight it because......
That was all they picked me up on! :P:D:D
*Passed*
Lowered - didn't check
Exhaust - ditto (didn't look under the car @ all!)
K&N pod filter
A Pillar mounted boost gauge
Razo pedal set
Aftermarket ECU/turbo - ditto
& plenty of other little potential no-no's
Things I fitted straight after the inspection (I mean that day!) that would be a good idea to NOT have fitted for the inspection:
Oil catch can (regardless of set-up ie legal or not)
Aftermarket BOV
I wouldn't have dark tint either as they REALLY target cars with dark tinting!!! Dunno' why?
The inspection only takes 10-15mins max & any minor drama you can do & come back, same day (I fitted my stock s/wheel & passed a few hours later).
But........ I got my inspection done @ another station south of the City, can't remember the name of the place now, but can recall how to get there! I took it there as they only did VII's & therefore no waiting list, just rock up & in you go! They were less likely to go over the car with a fine tooth comb as well!
Hope this info is of some help mate.
Originally posted by whatsisname
*Failed*
Aftermarket BOV
DOH. Where abouts is this other inspection place - sounds like it might be worth a shot.
So your in the defence force - which one? I am one of those too, just got posted to Edinburgh, but I am a submariner (dont hold this against me...lol) - Now I'm postwhoring my own thread. hehehe
Thanks for your reply
Steve
Steve,
I'm an AVTECH in the RAAF (14yrs). I've been @ Aircraft Research & Development Unit (ARDU) for ~18mths, so pretty much Edinburgh too :) Currently the main ARDU area is 2mins drive from the base but our new facilities on the base are scheduled for completion late this yr.
I'm guessing we'll cross paths from time to time :P
As for the 2nd inspection station, I can't recall the name of the area? But I can find my way back there from memory, if need be mate ;)
Originally posted by hippy
how come the pillar mounted gauges pass?? i thought they were illegal??
I don't know what the legalities are with regards to additional gauges? But I have "heard" that clearance is the major issue. Clearance from potential head injury in an impact, & from obstruction of vision. My Autometer boost gauge neither blocks my vision nor poses a risk of impact in a crash.
I don't think the inspectors were that concerned with my gauge/A pillar mount, maybe they were in a good mood that day? It was a Friday.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
