(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:Apexi AVCR
Item Condition:used
Reason for Selling:sold my car
Price and Payment Conditions:$300 direct deposit or pick up or cod
Extra Info:still in good condition
Contact Details:pm me for more detail.
Edited by hksrb26
https://www.sau.com.au/forums/topic/94298-apexi-avcr-boost-control/
the thing does not work, i have had it professionally installed by a workshop and they have told me that it does not work. he has sold me a dud and his mobile phone is always off.
if you do not reply to your pm. i will advise my solicitors and take leegal action. i have your details.
unlucky dude
hope it all works out
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
