Guest a31rb25
1989 A31 Nissan Cefiro
(pig spec)
RB25DET
R33 GTS-t 5 speed box
Blitz LM Pod
jap spec exhaust
R33 Brake upgrade
5 bolt stud conversion
Mech 2 way diff
twin plate clutch (rattler)
Zenith Tuning steering bush
Zenith Tuning solid cradle bushes
Tein HR coil overs
unknown tie rods (no stickers on them, anodized blue if that helps anyone)
R32 GTS-t rims
dodgy kit (possibly Auteh copy)
series 2 tail lights
currently running the side-mount cooler (that's changing though)
coming soon
oil cooler
oil catch can
GTR fmic w/ custom alloy piping
Apexi Power FC
Z32 AFM
Sard 550cc injectors
stripped interior
full cage
new bodykit
paint n panel repairs
TRACK TIME
no idea of power, never had it dynoed.
https://www.sau.com.au/forums/topic/94388-my-ceffy/
Guest a31rb25
wow that will look mint once the paper mache on your front bar dries off!
hahaha only kidding you know i love you, nice car btw -
haha, yeah that was my first attempt at fixing fibreglass. glassed a fair bit of the inside to get some sorta shape into the front bar, it was pretty badly smashed up. the bog work down the bottom of the bar hasn't been sanded back yet.
when i bought the car, the previous owner in japan had attempted to fix the bar by using some sort of tape on the inside and some flakey polly filler type stuff on it. it was dodgier than my attempt. most of the screw holes were smashed and the bar doesn't line up properly anyway so it's got that "the owner is a tight-ass" zip-tie look.
might have to buy one of those wonder copies from D1 Garage
https://www.sau.com.au/forums/topic/94388-my-ceffy/#findComment-1709236
well done mate. i post up a pic and specs of my car for other ceffie owners to see, and get called an attention seeker. cheers!
Settle down dude :lol: it was only because there is already a thread for posting up pics and details of ur car. Huddys is a special case because everyone (especially me) was hounding him for pics and details of the car.
Just a joke, as funkymonkey could see :P
https://www.sau.com.au/forums/topic/94388-my-ceffy/#findComment-1709410
hahahaha the grandpa that owned my car in japan reversed into something and they patched the ding up with this white bog....
let's call it "wog" for the time being,
it was only a small ding, but the wog was very ugly
and within two weeks of having my car on a foggy perth evening i reversed into my dad's van in the EXACT same spot....
....it was gay.
https://www.sau.com.au/forums/topic/94388-my-ceffy/#findComment-1709890
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
