OS Giken Triple plate clutch including flywheel, this is a pull type clutch and can be used up to 700+hp. Made to fit R32 GTR, R33 GTR and R34 GTR.
second hand, 95% brand new, plates are in excellent condition.
pics will be edited here and posted preety soon!
price: $2000
https://www.sau.com.au/forums/topic/9483-os-giken-triple-plate-clutch/
  • 5 months later...
  • 3 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
