  • Replies 169
Posted Images
Thanks guys attendance list updated
make sure u please send me ur name, #. so we can check on the day if you are there. if u are running late please give me a call, or you will be left behind.
we will do attendance check before we go.
this will be a good day B)
This is looking good ppl, im planing to have a BBQ, does anyone has a mini one we can take with us????
i hope the sun is up for this day, i will not be happy if it doesnt :P
for all the ppl who has not yet game me their details, eg phone #, real name, please do so, so i can let you know if there is some changes.
thanks guys :P
Only likes driving on twisty roads?
What does he think Newcastle is? All drag strips?
Anyway.
For you guys who are wanting food/BBQ's the place where we were all going to meet up with Newcast;e crew is at a place called Bar Beach.
I'm fairly sure they still have a kiosk there.
And as its a beach, lots of swimming can be had. Its actually one of the better beaches up here IMO.
I spose I should give you guys leading the pack some kinda vague directions or something...... just in case
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
