definately a bike shop, the race shops will change a fortune
YEP, you can pick up plenty of bargains for helmets either off the web at some of the aussie bike sites or from your local bike dealer.
Need any sites to look at then PM me and i'll let you know the best ones :)
Cheers B
https://www.sau.com.au/forums/topic/95130-helmet/#findComment-1721770
ebay is your friend, ask the seller to check if the helmet has the correct ISO stickers on it before buying, and make sure it hasn't been thru any major accidents or have cracks. I bought mine for $50, the previous owner took it on hillclimbs and other CAMS events, so it had all the mic and earphone attachments too.
https://www.sau.com.au/forums/topic/95130-helmet/#findComment-1736676
there's a place in kirrawee, can't remember the name of the street, same street as the back entrance of maccas, it's like next to cronulla car sound, you just go in from the back and go upstairs into like a bike shop or something.
I think it's called monroe avenue or something.
https://www.sau.com.au/forums/topic/95130-helmet/#findComment-1746257
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
