Hey People,
I have read up on the various o2 threads.
I am trying to find out what readings your Power fc gives for the 02 sensor at idle and cruise conditions is it the same as the R33 gts 0-1V?
This can be found in the etc mode under sw check
Thanks
also for a gtr with mild mods
full exhaust
cam gears
PFC
what sort of L/100kms are you getting
Highway and city
I get 300city and 350 Highway on a full tank (taking it easy)
Thanks alot
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/
It should oscillate between about 0.1-0.9 volts holding it at 2000 rpm and in a steady state cruise situation. Should be the same for amost any votage based 0-1 volt O2 sensor. Thing to check is the bias to chassis ground and also ecu ground.
It should also be checked with a wide band o2 sensor to show that the 02 sensor is not slow to react. Often harder to tell then just a faulty sensor.
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1722366
Thanks for the help, the bias to chasis ground where is the best place to check this?
Also I think the R32GTR and R33 GTR have different 02 sensors R32 is the smaller style nut R33 is Large style but the Power fc is for both r32 and r33
Does the 32 o2 sensor even work with power FC?
This is the same as S13 early models (red top) have small style late models have large style nut eg (black top)
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1722769
They both use a 0-1volt range as far as I'm aware so it should have an issue PFC. Chassis ground - as in anyware you can get a good contact to ground ie in a bolt hole. All your doing is checking that there is no voltage between grounds for the o2 sensors and chassis or ecu.
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1723151
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
