Item: Bolt-In Eyelids to Suit R32's
Item Condition: New
Price and Payment Conditions: $149 - Direct Deposit, Paypal, or will COD at buyers expense.
Extra Info:
Unlike stick-on eyelids that only cover the face of the headlight, these fibreglass eyelids cover the top and face of the headlight. A unique design secures them to the car with brackets rather than double-sided tape.
Because they bolt-on, it also makes it more difficult for would be thieves to rip them off the car (actually with the bonnet closed it is damned near impossible :D ).
More pics will show up here in time :P
Contact Details: If interested you can contact me via PM or email
https://www.sau.com.au/forums/topic/95333-bolt-in-eyelids-to-suit-r32s-d/
These ones actually do something.
If your driving sedately they close some what, and blink. Then when your fanging it, they squint and give your car a more concentrated or focused look.. Then if they see other R32s particularly the GTR model or if they detect hot bitches near by... they wink!
I've got a set. MAD
Thanks for the informative comments :P
Yes they are purely an aesthetic mod - just another bodykit piece, BUT they give the r32 a much needed facelift.
Sorry no bonus kw here unless you put a GTR sticker on them :)
I've got a set. MAD
(please note that eyelids may not actually blink :P )
ok guys, enough whoring, back to the fun B)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
