Hey Guys,
First just want to say thanks to the guys that came.
Zoggy
N1GTR
Mr_G
BLK R33 GTST
Ihatespanners(not sure how your nick is spelt)
Mr 32
SiddR20
And "Red Fto" (dont know username, sorry mate)
I think everyone was stunned seeing all those skylines....at the same time....
Anyway, here are the pics...
Thanks again guys
Stel
Edited by Stel
https://www.sau.com.au/forums/topic/95458-formal-cruise-photos-18th-november/
  • Replies 64
Posted Images
Thanks for the cruise guys, was great to meet some faces... But would like to put cars to names...
As you know, im Mr_G on the forums, but im Jason by person and this was my ride (attatched)... I was piloting and Siddr20 was passanger.
Great cruise guys, too bad the random that rocked up with the maroon r32 didnt hang around... If only his g/f brought some freinds??? Enough to share between us all!! :P
But ya, great cruise, we got to do it again sometime :D
heheh we can always do it on 3rd dec.. Sisters formal.. anyone interested??
Spounds gret ill be there
Of by the way im the one with the black r33 with gold BBS 17" rims and sunfroof B) , Tim , if anyone forgot
I had the slight idol problem , took it to the mechanics this morining , charcole tank wasnt connected properly, 5 min job :P car is back and running better then ever :D
Pics turned out well, thanks for the cruise boys , ill be there for any more cruises
- Tim
hehe gald u fixed your problem with ease..
Hmm i think her formal is 1st dec actually.. coz i remember she sayin it was on a thursday.. hmm..
Will post up details soon..
Tim, we had a black 32 that was keen on my sisters cruise, but he sellin his car n everything so he cant make it.. One of my sisters friends loves black 33, so if possible anychance u can come..
But i will post up details n all n let you know. .
Cheers man..
- Tim
Thought it was the charcoal can :( Nice n cheap, probably free :)
I had the slight idol problem , took it to the mechanics this morining , charcole tank wasnt connected properly, 5 min job  :(  car is back and running better then ever  :(
- Tim
hey tim im quite sure i see ur car on the way 2 work and also at ur work, do u work at AGS? ive cruised next to u a few times on the way 2 work, i have a black r33 gtst, gtr wing, rims, fmic...red number plates that say B0.05.TY
i work near ya if its u
He does work at AGS as I was speaking to him last night... Tim, you gotta let us in that carpark :(
hmm actually formal is on 8th dec.. thursday.. hmm can anyone make it..
haha yea she has hot friends.. lol..
that shouldnt be a problem, where abouts is her formal and where we meeting up to pick her and her friends up
Hey, I remember youcant forget a number plate like that ... see you a few times on Forsore rd, Yeh i work at AGS, were abouts do you work.. ive nver seen you come onto the complex,
whats your name?
Great cruise guys, nice to meet u guys........next time i will try to hang around a bit longer.....
Whens the next one? ? ?
Hey Zoggy i work round the corner from u.....i work at TNT @ Matraville, i'm supprised that i haven't seen u more often
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
