Just got a 96 GTR and my mechanic has recomended first point for upgrade to wack a 3.5'' exhaust right through.
Wondering what is Legal and How do I find out what the legal limits are in QLD.
Also he rekons it will add about 40 rwkw , does anyone have any experience with this ??
regards sb..
https://www.sau.com.au/forums/topic/95652-r33-gtr-exhaust-upgrade/
The problems you will have is with the car being to low due to the exhaust going under the diff/drive shafts ect, the police will love to defect you for this, and also the biggest problem you will have is noise. 92 DB is the legal limit, i have a 3" exhaust right through and without the silencer i'm 102db @ 5100rpm. You should gain a fair bit of power from those mods, when doing this also get a set of pod filters or get a good pannel filter, something less restrictive. You should be able to up the boost to 1 bar and should be making around the 200awkw mark. Mine has the following done and is making a tad bit more power than that.
96gtrman i made my own 3.5' system with with twin 3' down pipes into 3.5' straight throught two the rear where at the time i could not buy the muffler(s) i wanted so as a tempary measure i cut the back off the standard unit gutted it and fitted the 3.5' into rear with the twin 2.5' standard tail pipes, the result was quiet awesome since then i have made 530rwhp with the system and i great a number of comments on the note of the gtr which is not really that loud so cruising isnt a problem/or police but it still has a nasty angry note. I used all mandal bends and also made custom 3' one piece dumps(like what tomei sell)
pete
ps if you take your time fitting it you can have it hang at the same height as std the diff is not a problem
Edited by pnblight
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
