This is my thread for the things I find out as my engine gets rebuilt.
I blew the ringland between the 2nd and 3rd rings in no.6. All the other pistons were pitted etc.
The rods are indeed the same as GTR rods (anyone want to buy the set I bought in case they weren't :))
It appears that the head uses quite a different design than previous RB25's. More details to come.
It uses a RB26 style oil pump but retains the short drive on the crank like early RB26's and all RB25's so I'm going to try to source a Jun crank collar.
At this stage I'm thinking of 8.8:1 compression ratio to give me a bit of safety with the tune but hopefully not losing too much in the way of response or power. I've had everything from 8.2 to 9+ recommended to me which has been confusing.
Removing the engine wasn't too hard with the help of Duncan and Ed. Thanks guys.
I think that's it for now.
https://www.sau.com.au/forums/topic/95854-my-rebuild-and-what-ive-found-out/
  • Replies 183
Stock compression wasn't measured.
Blew it - http://www.skylinesaustralia.com/forums/in...topic=87738&hl=
Can't rely on the availability of Optimax 100 just yet.
Bass junky with the same setup to what I will have (ie cams and turbo) could only put 0.9 bar into his engine but got great power there so I thought that with a little less compression I might be able to squeeze in the extra boost to make up for lower CR plus a little more for happy days.
Some pics to come.
I spoke to GCG today about my turbo maxing out at 14 psi.
He said that he's never heard of one making that power at that boost.
He said they were most efficient at about 17 - 18 psi.
I'll get to the bottom of this. Maybe RacePace are just the worlds best tuners.......
Abobob,
Its definitely a concern, go with an 8.5:1 to be safe. :D
On that note I believe Freebaggin is still running the stock 9:1, he hasnt mentioned the use of a thicker headgasket.
He's running an internal gate .6 something GT3040R. I remember back when it was first fitted, ~270rwkw on 17psi, he has since fitted 256duration cams and cracked 300rwkw. Its not on an optimistic dyno either.
It's not a NEO. Maybe the Neo has some issues with cam timing or something silly? I'm not 100% sure on the NEO VCT, is it constantly variable or??
Edited by Cubes
I will be fitting the Tomei Tybe B Poncams which are 260 degrees both sides and 9.15 lift. This will lower my dynamic compression ratio a little and hopefully make it a little more resistant to detonation.
I don't know anything about the VCT. As for cam timing, all I know is that adjustable cam gears have been proven not to work on the NEO.
Bass - maybe GCG are making better turbos than they think because I had 228 at 0.85 bar, no cams and auto. One dyno operator reckoned that was close to 250 in a manual although I think the R34 auto seems to be a less lossy transmission than some. It makes me wonder if Sydneykids GTT had a turbo with different specs (ie GCG are doing them different nowadays) or that it had a thicker head gasket in place before he saw it because with the same cams it takes an extra 0.5 bar to make not that much extra power.
And let's not forget the reputable workshop who told me not to expect more than 220 at the limit of the turbo. Methinks some people have an agenda.
Here are some photos my engine builder sent me last night.
Agenda? Definently.
SK's 265rwkw figure was recorded in Shootout mode which at 250rwkw reportedly gives about 10-15 rwkw higher figure.
Until the next dyno day on a shootout dyno, I'll not know what my car makes in shootout.
I have the same cams Abo Bob.
Here's my power curve.... It's fat.
Agenda?  Definently.
Thats a nice curve, must be pretty damn quick on the street.
So you guys really rate the GCG hi-flow as the best option for the 34GTT? I have an auto as well and probably chasing 250rwkw for the time being. How much extra kw will this turbo give just by itself :D I'm currently on about 200 so I don't know. If it's a long way off, I might as well get a different turbo.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
