This is my thread for the things I find out as my engine gets rebuilt.
I blew the ringland between the 2nd and 3rd rings in no.6. All the other pistons were pitted etc.
The rods are indeed the same as GTR rods (anyone want to buy the set I bought in case they weren't :))
It appears that the head uses quite a different design than previous RB25's. More details to come.
It uses a RB26 style oil pump but retains the short drive on the crank like early RB26's and all RB25's so I'm going to try to source a Jun crank collar.
At this stage I'm thinking of 8.8:1 compression ratio to give me a bit of safety with the tune but hopefully not losing too much in the way of response or power. I've had everything from 8.2 to 9+ recommended to me which has been confusing.
Removing the engine wasn't too hard with the help of Duncan and Ed. Thanks guys.
I think that's it for now.
https://www.sau.com.au/forums/topic/95854-my-rebuild-and-what-ive-found-out/
  • Replies 183
Stock compression wasn't measured.
Blew it - http://www.skylinesaustralia.com/forums/in...topic=87738&hl=
Can't rely on the availability of Optimax 100 just yet.
Bass junky with the same setup to what I will have (ie cams and turbo) could only put 0.9 bar into his engine but got great power there so I thought that with a little less compression I might be able to squeeze in the extra boost to make up for lower CR plus a little more for happy days.
Some pics to come.
I spoke to GCG today about my turbo maxing out at 14 psi.
He said that he's never heard of one making that power at that boost.
He said they were most efficient at about 17 - 18 psi.
I'll get to the bottom of this. Maybe RacePace are just the worlds best tuners.......
Abobob,
Its definitely a concern, go with an 8.5:1 to be safe. :D
On that note I believe Freebaggin is still running the stock 9:1, he hasnt mentioned the use of a thicker headgasket.
He's running an internal gate .6 something GT3040R. I remember back when it was first fitted, ~270rwkw on 17psi, he has since fitted 256duration cams and cracked 300rwkw. Its not on an optimistic dyno either.
It's not a NEO. Maybe the Neo has some issues with cam timing or something silly? I'm not 100% sure on the NEO VCT, is it constantly variable or??
Edited by Cubes
I will be fitting the Tomei Tybe B Poncams which are 260 degrees both sides and 9.15 lift. This will lower my dynamic compression ratio a little and hopefully make it a little more resistant to detonation.
I don't know anything about the VCT. As for cam timing, all I know is that adjustable cam gears have been proven not to work on the NEO.
Bass - maybe GCG are making better turbos than they think because I had 228 at 0.85 bar, no cams and auto. One dyno operator reckoned that was close to 250 in a manual although I think the R34 auto seems to be a less lossy transmission than some. It makes me wonder if Sydneykids GTT had a turbo with different specs (ie GCG are doing them different nowadays) or that it had a thicker head gasket in place before he saw it because with the same cams it takes an extra 0.5 bar to make not that much extra power.
And let's not forget the reputable workshop who told me not to expect more than 220 at the limit of the turbo. Methinks some people have an agenda.
Here are some photos my engine builder sent me last night.
Agenda? Definently.
SK's 265rwkw figure was recorded in Shootout mode which at 250rwkw reportedly gives about 10-15 rwkw higher figure.
Until the next dyno day on a shootout dyno, I'll not know what my car makes in shootout.
I have the same cams Abo Bob.
Here's my power curve.... It's fat.
Agenda?  Definently.
Thats a nice curve, must be pretty damn quick on the street.
So you guys really rate the GCG hi-flow as the best option for the 34GTT? I have an auto as well and probably chasing 250rwkw for the time being. How much extra kw will this turbo give just by itself :D I'm currently on about 200 so I don't know. If it's a long way off, I might as well get a different turbo.
    • Hot tip, stop picking at shit. Live in bliss instead   From my recent experience in rust repairs, white it may seem to not go much further back, you'll still need to cut back a bit further.  From what I can see there, the outer skin, and the inner is rusted too. From what I can see you've got the inner one which is all structural, and window likely affixes too.   If tag Murray Calavera here, but my phone won't let me tag him, he'd probably be able to give the best advise.   I do know, welding roof panels is a right pain in the bollocks! Very heavy to heat distort the roof and warp it all.
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
