Ok so im not sure if its true or not but i heard that there is a locksmith that can cut the factory Nissan imort key (eg: for a R32 GTS-t) without having to buy a blank key from Japan.
Anyone know if its true or had it done and where abouts?
Cheers B
https://www.sau.com.au/forums/topic/95890-spare-key-cut/
You can buy the blanks from your good old local Nissan dealer. Nothing speacial about the keys, same as most locally delivered stuff. I brought as blank off Von Bibra's up he for my R33, cost not much more than $20. Then got it cut off the code number at the local locksmith.
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1735706
lol i got a key cut in burnie for my car the other day R33 didnt cost much think it was 5 bux i think. just a standard key though.
BTW wogboy have you been to Rosebery L8ly i think i seen your car down there not so lnog ago.
Edited by drumstick29
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1736331
Went through there a couple of months ago on the way to Strahan. Stopped and had a coffee. I went to school there.
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1738778
Was your car parked out Sth Rosebery. Saw a R33 out that way.
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1738785
Yeah $5.50 I think I got charged in Kingston, took about 3 minutes and works a treat!!
Well i got mine cut from Darren as well but it doesn't work <_<
Goes into the ignition fine, just wont turn :)
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1739057
Well so far i have had 3 keys cut at 3 different locksmiths and none of them work. All will go into the ignition but none will turn the car on.
Looks like im one of the unlucky ones and will have to pay $50 for a NISMO blank key :)
Cheers B
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1767840
Looks like im one of the unlucky ones and will have to pay $50 for a NISMO blank key :D
Cheers B
I noticed with my silvia keys (they obviously have been cut) they only work one way around, as in you put it in the barrel and it slides in fine but won't turn, take it out rotate it and put it back in and its fine!
also you barrel could be slogged out and isn't accepting a fresh cut key (how was the condition of the old one?)
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1769890
Yeah thats what i thought as well (more like hoping) but when Darren looked at the barrel he said it was fine, and that without the proper blank he wouldn't be able to match it up (or get it work).
So looks like if i loose my keys then im good and proper fooked :D
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1769902
hey b, got one cut for my car about a week ago... no problems at all :(
how does "go FARK urself" sound SAMMY BOY.
My stock car still will beat yours and thats all that matters...
Just dont steal my key or then im FOOKED :lol:
https://www.sau.com.au/forums/topic/95890-spare-key-cut/#findComment-1787235
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
