I dont even know if my fuel light works... is there any way to check it? Everytime i fill up and its on E i only put in max 45-50 L's and the tank is apparently 65L's... is there anyway to check if my gauge is broken??
I would assume there is probably between 5-10l's in the tank once the lights on?
Dayne
https://www.sau.com.au/forums/topic/95978-fuel-light/#findComment-1737583
ive done about 30kms after the light came on. be careful though, when it gets really low and you go around corners the fuel moves around and u loose power as the pump starts sucking air. Not a very good for your pump i dont think, i was told they rely on fuel flowing through them to keep cool.
https://www.sau.com.au/forums/topic/95978-fuel-light/#findComment-1744650
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
