GTSt SONY setup
Guest alexR33
Hi !
I promise to be brief!
Hypothetically if i could ONLY get SONY...So don't tell me sony suck. in this siituation ONLY SONY exists. What would you suggest out of the current range, including specific models for Head Units and splits, subs, etc. To set up a R33 GTST Series2, I have some speakers 6x9s already for the back, just want a DECENT set up, nothing that wins comps, but cost effective and something the average person would be impressed with! Only sony. I can buy direct off a mate. So that should explain that...
To be completely honest, i know very little about what the different specs all mean. I'm only after one suby and tweeters and splits and a hhead unit and amp i think.
Thanks for your time!
Alex
https://www.sau.com.au/forums/topic/9638-gtst-sony-setup/
Depends whether you get a real discount or you just think you're getting a discount 'cause he says you are :)
You did ask for Sony only, but i'm gonna say it anyway.
For that sort of price everything in the Pioneer range (or many others) is better..seriously, i owned some Sony speakers and they weren't too crash hot - and then after a couple of years of amp'ing they started going cactus... and i'm not even a massive volume person. I'd really reconsider the Sony unless you can get them for some massive discount (50% off or something)
Other cars with Sony stuff have not sounded good to me either. If you're going a full setup, don't just buy Sony if you're going to spend $2k or so or the lot.. a lot of the Sony stuff is more expensive than other equivelents in the first place so you might not actually be saving that much.
https://www.sau.com.au/forums/topic/9638-gtst-sony-setup/#findComment-148339
Whats the chances of you gettin me a Sony TV???????
Sorry guys i disagree, cos ive had SONY all my life in my 33 and in my house and ive had no problems, and the sound of when i had just one 12 inch sub in a chipboard box a couple of years ago was unbelivble.
But hey everyone is entilited to there own opinon.
https://www.sau.com.au/forums/topic/9638-gtst-sony-setup/#findComment-154846
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
