i have no idea about suspension on cars so hear come a few stupid questions....i must warn you in advance :D
are Tension Rods/Radius Rods/Castor rods the same thing? ive seen pictures and they all look identical
also ive been told that i need new castor rod bushes. should i just spend the little bit extra and get something like this:
http://cgi.ebay.com.au/Tension-Rods-NEW-CN...1QQcmdZViewItem
or
http://cgi.ebay.com.au/ADJUSTABLE-RADIUS-R...1QQcmdZViewItem
also when i get the the tension or radius rods do they come with bushes?
THX
https://www.sau.com.au/forums/topic/96782-tension-rodsradius-rodscastor-rods/
radius rods (castor rods-castor arms) are only attatched with 3 bolts and nuts. They obviously replace ur old ones and are bushless so to speak. The 2 threads at the ends just have a bolt and washer and the other end has like a "floating" as i would say bearing and has a bolt and nuts that attatches is. It has a swivel head and moves accordingly. A great upgrade tho i must say, adjusting to a good +castor rate of +8,9 is perfect.
I strongly suggest that you have read of this thread and then you can make up your own mind which way you want to go.
http://www.skylinesaustralia.com/forums/in...4&hl=sphericals
:) cheers :P
yeh they are a little harsher for street, especially on tyres, ul notice ul go through ur fronts a little faster....i dont really care tho..if u can get secondies cheap it dont matter.......they help out majorly
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
