dude my hicas light has been on forever, with hicas and now without.........hicas lock kit. My suggestion - lock it off with a hicas lock kit, ur light will most likely still show, but pay no attention to it - i dont and my steering hasnt been affected.
my 3.14 cens worth
https://www.sau.com.au/forums/topic/96798-hicas-light/#findComment-1757840
have u ditched ur hicas yet? if your in adelaide, the last time i was in Kansai they had a hicas lock kit for $190 i think. go there, grab it and install it.......its a piss of p*ss to install, if u need directions pm me and il walk u through it
https://www.sau.com.au/forums/topic/96798-hicas-light/#findComment-1760598
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
