im getting a GTR R33 pretty soon and just wondering how can u tell if your turbos on the R33 r getting worn out or not(the car has done around 68000 ks)? im asking this becoz the ceramic turbos do have failures after a while and when the wheel falls off the turbo and gets sucked into the motor, i would be f**ked. any help would be appreciated.
thanx :)
https://www.sau.com.au/forums/topic/97025-signs-of-turbo-getting-worn-out/
