Hi all,
Just starting to play around with the idea of eprom tuning. Just wondering if anyone has the bin and adr files for a RB20DET [silver top]?
Looked around everywhere but keep getting dead links.
Any help would be great.
Cheers,
Shaun
https://www.sau.com.au/forums/topic/97122-wtd-rb20-and-26-eprom-files/
rb20det.com
grab the bin from there
and below is the contents of the adr file, drop the text into a .txt notepad file then rename its file extension .adr.....
and then tell me what to do with them :lol:
i have the rom editor 1.98 program thingo but thats as far as ive gone
Edited by inissane
# NISSAN HCR32 RB20DET MAP ADDRESS (E)
# Variable,Start-Address,X,Y,Map size,value,Map-name
#UNIT NAME
TYPE_UNIT,HCR32(RB20DET) type-M,*,*,*
#HIGH/LOW octane Fuel map.
HIGH_FUEL,&H7D00,16,16,256,1,High octane Fuel map
REG_FUEL,&H7500,16,16,256,1,Low octane Fuel map
#HIGH/LOW octane Ignition time map.
HIGH_FIRE,&H7400,16,16,256,1,High octane Ignition timing
REG_FIRE,&H7C00,16,16,256,1,Low octane Ignition timing
#K required number
K_DATA,&H7F2B,2,1,2,1,K Multiplyer
#Void blast-off time
IGN_TIME,&H7F88,1,1,1,1,Injectors Lag time
#Feedback control
FB_SWITCH,&H7F91,1,1,1,1,Start Temp for Closed Loop
#VQ map
VQ_MAP,&H7A70,16,1,128,1,AFM Voltage Correction Map
#Fuel/Ignition time TP scale
TP_SCALE_FUEL,&H7AF0,16,1,16,1,TP scale (Fuel)
TP_SCALE_FIRE,&H7B10,16,1,16,1,TP scale (Ignition time)
#Fuel/Ignition time RPM scale
RPM_SCALE_FUEL,&H7B00,16,1,16,50,RPM scale (Fuel)
RPM_SCALE_FIRE,&H7B20,16,1,16,50,RPM scale (Ignition time)
#TTP MAX/MIN
TTP_MAX,&H7E90,16,1,16,1,MAX Injection Quantity
TTP_MIN,&H7E80,16,1,16,1,MIN Injection Quantity
#TP Limit
AF_LIMIT,&H7960,16,1,16,1,AFM Fuel Cut
#Rev.Limit
REV1_LIMIT,&H7F8b,1,1,1,50,Rev Limiter 1
REV2_LIMIT,&H7FB4,1,1,1,50,Rev Limiter 2
#Speed Limit
SPEED1_LIMIT,&H7A0A,2,1,1,2,Speed Limit 1
SPEED2_LIMIT,&H7A0B,2,1,1,2,Speed Limit 2
SPEED3_LIMIT,&H7FA5,2,1,1,2,Speed Limit 3
#Add.map 1
ADD_MAP1,&H7940,16,2,32,1,Idle control (MAX)
#Add.map 2
ADD_MAP2,&H7980,16,2,32,1,Idle control
#ADD.map 3
ADD_MAP3,&H7E40,16,1,16,1, Fuel Increase Vs Temp (-40 to 110 deg Celcius)
#ADD.map 4
ADD_MAP4,&H7E60,16,1,16,12.5, Target idle rpm table (-40 to 110 deg Celcius)
#ADD.map 5
ADD_MAP5,&H7E10,16,1,16,1, Idle ignition timing table (other than neutral)
#ADD.map 6
ADD_MAP6,&H7EA0,16,1,16,1, Idle ignition timing table (neutral)
#ADD.map 7
ADD_MAP7,&H7B60,16,2,32,1, Ignition Coil duty table
That bin file from RB20det.com is my stock bin file from my 92 r32.
Its version is MEC-R212B and it does work in earlier version 1989 R32 ecu's aswell.
Look at the http://forum.ztechz.net/
lot of stuff there that can help you out.
Thanks guys. That RB20 bin goes fin in my GTS-4.
Anyone got RB26DETT bin and adr files?
GTR Address File(Romeditor)
If you want a GTR bin file just email me.
Cheers Lads.
# NISSAN BNR32 RB26DETT MAP ADDRESS (E)
#UNIT NAME
TYPE_UNIT,BNR32(RB26DETT) GT-R 2,*,*,*
REG_FUEL,&H7200,16,16,256,1,Low octane Fuel map
HIGH_FIRE,&H7400,16,16,256,1,High octane Ignition time
REG_FIRE,&H7C00,16,16,256,1,Low octane Ignition time
#K required number
K_DATA,&H7F2B,2,1,2,1,K required number
IGN_TIME,&H7F88,1,1,1,1,Void blast-off time
#Feedback control
FB_SWITCH,&H7F91,1,1,1,1,Feedback control
#VQ map
VQ_MAP,&H7A70,16,1,128,1,VQ map
#TTP MAX/MIN
TTP_MAX,&H7E90,16,1,16,1,TTP MAX
TTP_MIN,&H7E80,16,1,16,1,TTP MIN
#Acceleration increase volume
ADD_FUEL,&H7200,16,1,16,1,Acceleration increase volume
#Rev.Limit
REV1_LIMIT,&H7FB4,1,1,1,50,Rev. Limit 1
#Speed Limit
SPEED1_LIMIT,&H7FA5,2,1,1,2,Speed Limit 1
#Add.map 1
ADD_MAP1,&H7940,16,2,32,1,Idol getting a stabilization control
#Add.map 2
ADD_MAP2,&H7B30,16,2,32,1,Temperature of the water value conversion
#Add.map 3
ADD_MAP3,&H79E3,9,1,9,1,Knock limit
  • 9 years later...
i just lost all my tunes on my external hard drive ;(
does anyone have any tunes for 1000cc injectors, t8834d turbo for a rb26??
email [email protected] underscore between the y and f
thanks tay
I bought a haltech before I could upload it to the ECU from the hard drive , I broke the hard drive. Here is the hard drive
rb26dett tiwth t8834d , 1000cc injectors high impedance 12.5 ohms, haltech
http://imageshack.com/f/idutFnkfj]http://imageshack.us/v2/150x100q90/661/utfnkf.jpg
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
