Hey Guys,
My name is Jake and i am a new member to this forum...
I have owned a 1994 R33 Series 1 Skyline GTS-T for about a year and half and i am most impressed with the car...
However due to a family arriving within 8 months i need to sell my pride and joy :D
I just curious about how much it could be sold for... Here are the Mods done to it..
- Apexi Power FC + Controller
- Apexi AVCR (Electronic Boost Controller)-(Black Limited Edition)
- Front-Mount Intercooler
- K&N Pod Filter
- Full 3 & A Half Inch JASMA Exhaust
- After-Market Larger Turbo
- 115,000 Kms
- Front Body Kit & Side Skirts
- 19 by 8 Inch rims (Dolce DC-6)
- Momo Steering Wheel
- Boost & Air/Fuel Ratio Gauges
- GTR Dash
- RAZO Shifter & Pedals
- Advan Tuned
- NIZMO Blue Colour
- Pioneer 4 x 6" Splits, Pioneer 4 Channel AMP & A Fusion 10" Sub
- 290 At The Wheels
Also I apologise if i posted this in the wrong area, please tell me if i have and i will post in correct are in the future... I appreciate any help you can give me and if any prospective buyers please contact me... (If you require Photos please just ask)
https://www.sau.com.au/forums/topic/97561-for-sale/
Ne man, i am lookign to sell it and has been moved to classifieds area....
Most recomended i try for abour 21,000...
So if your lookign for the car with pictures and more info it in the classifieds area...
also it is very for sale...
Thanks
https://www.sau.com.au/forums/topic/97561-for-sale/#findComment-1772815
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
