Exactly, I had a lightened flywheel in my car, it shit me on the street, when going slow, couldn't go below 2000rpm without the car shuddering/labouring.... im back to a stock flywheel now.
You must have had a dodgy one.
It's a shame because a good one has absolutely NO downsides as far as driving around town is concerned.
Next time try a better brand. I found the Ogura chromemolly units (4.8kg) work mint for RB's. Excellent ballance.
Always sad to hear when someone gets something substandard.
On topic again....
Group buy wise I shall make inquiries now for something that will end in late Jan early Feb?
We will see if we can get a target price just below the $2k mark delivered if that is possible. Its already a bargain I think as it is but, if we can get a few more guys on board we might get it a little keener on the price.
  • Replies 119
Posted Images
My car has a lightened flywheel - it's nice to drive overall, I wouldn't really fault it, except with the air-con on, in second gear (or higher), braking, the car often stalls. But, the engine feels much, much smoother. It doesn't whinge much at high RPM.
obviously the tailshaft has nothing to do with the drivable nature of the car other than the fact that the carbon units actually eliminate more harmonics, therfore making things much smoother potentially.
I think we should have the 'flywheel' debate on a different thread althogether.
  • 3 weeks later...
I'm not sure if anyone has mentioned it, but doesn't the 350z come standard with a carbon fibre driveshaft? The pro's being the lighter weight, and if it snaps in any place it shatters rather than spearing as metal would (read:safer).
It'd be nice if these could some how be modified to fit, although being a genuine nissan item, it would probably work out to be more expensive than the aftermarket.
  • 3 weeks later...
I have an OS Giken flywheel on my GTR and an Exedy on my S15.My S15 kicks and bucks,its downright horrible,the GTR is as smooth as hell,both cars use twin plates.
I'm in for this group buy.
That explains it. I had an exedy. :ban:
I wasn't going to post this while the topic was still hot but what effect would this have with an auto?
How does the info we have about lighter flywheels translate/compare to autos?
With the auto you are going the opposite in some ways with the torque converter.
I'm noticing lately the weight of my car and will be looking at different wheels - at least for the track if not the street - but have found this discussion interesting.
sounds like you did not bed in the exedy clutch correctly. Fly wheel has got nothing to do with it. Both fly wheels are balanced from the factory. I've driven R32 GTR with exedy twin and mine has OS tripple. Both were not great until bedded.
I am keen on the GB as well.
we will have to start the group buy soon with a long wait period so people can save up the $$$$$$ i guess we will need 15 plus people to get a good saving rev210 was looking at it but i will give them another call and see if we can get that price down
  • 1 month later...
Ok I thought I had better get this thread back to the forefront again as I am put in the position of spending my cash on a rebuild :/ instead of this lovely item for the time being.
I am happy to help someone who would like to take up the 'group buy' batton to introduce them to ACPT.
$2100 delivered is cheap.
As a side note you might be interested in the fact that Carbon fibre shafts are used by pretty much all Pro-Stock drag racers for the basic reason that their 60ft times and overall 1/4 mile times are faster.
PM me if you would like to get a group buy on the go.
Guest Mashrock
Rev210
I'll be down for sure, but.. i beleive a custom one will be needed for me.
as i have thrown a 34gtr box into my 32 gtr, which from what i beleive will be a little shorter than the 32 one. i think from memory its a combo of a 34 and 32gtr shafts put together. but i can find out for sure when needed.
but it sounds good. as more response for circuit work is just what i am after for that little bit more edge
Guest Mashrock
mashrock,
get your measurements together, perhaps email ACPT directly to get their requirements?
no worries i shall give it a go, i will need to go to the shop to get measurements tho as its gettin put in now.
will the group by go through? there seems to be a fair bit of intrest
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
