Item: This is a 89 R32 gtr. It has a straight body and the engine compression tested up at 160 psi. 89000kms
Mods are:
Coil over hieght adjustable shocks
Blitz access tuned ECU
Twin blitz BOV's
Volk 17x9 GTC rims with 255 tyres.
2.5 inch front pipes
Trust 3inch exhaust
Greddy Profec boost controller
Greddy boost gauge
Short shifter
New exhaust manifold gaskets
Location:Cheltenham Melbourne. 20 mins south of the city.
Item Condition:
Reason for Selling:Need a deposit for a house and need it gone.
Price and Payment Conditions:$17500 or offers
Extra Info: If you don't have anything good to say. Don't post!
Contact Details:Call me Gareth : 0417370869
  • 4 weeks later...
I will be fixing the exhaust manifold leak next week so the car will be complete and ready to get a rwc. FurryBarry saw the car and is keen after I fix the leak. He said after looking at many other cars around $20k it was easily the best paint and straightest body. Last chance to get it cheap before I fix it!
I can confirm that the panels are nice and straight.
Comes with a nice set of cool retro volks, low and stiff suspension, full exhaust and a big chunky intercooler.
Anyone interstate or elsewhere who wants an independent opinion feel free to PM me.
I'm no longer in the running as I've just blown my wad of yen on this thing.
Thanks for your time on the weekend Gareth and good luck to all concerned.
Edited by FurryBarry
Really depends on the mods and condition. Wrx's don't really stack up against a gtr at all in any way buy their speed on the track or in a straight line. I would have to be a very good car.
  • 3 weeks later...
  • 1 month later...
So it just came over form japan is awaiting registration?
Also was it brought in under the 15 yr rule?
Roadworthy is not a problem for me, i have people in great places :P
I am in Cheltenham Vic.
The car has two months rego in Vic but will be sold without it.
In the pic it might have the carbon bonnet on but it comes with the stock one.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
