well guys, ive purchased a pair of gtr bovs and the assembly and was going to put them on my s14, just a few questions
why is there 2 on a gtr?
wat is the little 2mm or so hole that vents to atmophere in the side of the bov?
will i still get that cool "chooo" sound if i only use one? (blumbed back of corse) because fitting 2 in my engine bay might be abit harder than i thought it was going to be
also what do they bovs sound like when they vent to atmosphere?
thankx guys, any help appriciated :D
https://www.sau.com.au/forums/topic/97840-1-or-2-gtr-bovs/
2 bovs as there are two inlets, two afms, two turbochargers
each has its own recirclation valve and airflow meter reading so you need two
Nah, its actually one pipe, nothing to do with 2 turbos/afm's. Leewah/nige/ben all use big single's remember :D
If you look the stock crossover pipe thing they two BOV's join into the one hose.
well, thats what i thought from briefly looking @ my two im using on my next project :(
https://www.sau.com.au/forums/topic/97840-1-or-2-gtr-bovs/#findComment-1776794
I dont own a gtr but i think after the bovs come together that pipe splits into 2 again and one comes in infront of one turbo and the other the other turbo right?
i recon using one would be fine aslong as you have a splitter at the end so equal air is put back infront of each turbo, also only having one means only 1 vacuum line, so one of the existing lines would have to be blocked off
https://www.sau.com.au/forums/topic/97840-1-or-2-gtr-bovs/#findComment-1777368
Flow area - you could achieve the same effect by having a single larger one with the same flow
area as the two added together, but there are probably good reasons why Nissan went
with two smaller ones rather than one larger one that I'd hesitate to guess at. If you've got
the whole assembly you'll see that they join back to a single recirc pipe which then splits
back into two under the stock airbox and rejoins basically just before the inlet side of
the turbos.
no idea; having not pulled one apart I'd assume it's to permit air equalisation between the
atmosphere and the bit 'between the diaphragm and the valve itself'...
The sound's related to the volume of air and the speed it moves at - you might find that
one is louder/higher pitched than two together because the air will have to move faster
through a smaller total orifice and for longer to get rid of the same volume of air.
I've never tested the difference, so that's pure conjecture.
Probably very similar to any other VTA BOV. It's just air moving around, after all.
Some BOVs have funny characteristic sounds, but I doubt that the GTR ones
will... suck it and see :D
Regards,
Saliya
https://www.sau.com.au/forums/topic/97840-1-or-2-gtr-bovs/#findComment-1778139
just a question...do you "have" to have these 2 bovs on a RB26 since its using 2 afms ?
what happens if you dont have bovs on a gtr thats using a stock ecu and stock afm's?
thanks.
You mean if you take them off or replace them with a different single recirc BOV will the
car suddenly stop working ? No. My car doesn't have the BOVs; I removed them to
put an oil cooler in. It works fine.
But BOVs are supposed to have tangible benefits; one of them being that of less turbo
wear at gearchanges due to the turbos not 'running into a solid wall of air' if that makes
sense. And you'd need a fairly large single to give the same flow area as the twins;
I don't think I've ever seen one that big. _Someone_ probably has, though :D
Regards,
Saliya
https://www.sau.com.au/forums/topic/97840-1-or-2-gtr-bovs/#findComment-1778169
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
