Hey all,
i've got a Trust RSPL intercooler up for grabs that i was going to mount upto my silvia but it proved too large for my application so im looking to downgrade to an 80mm core or so. As can be seen in the pics, there are a few bent fins but nothing substantial enough to restrict airflow (or will it :P)
The dimensions of the cooler is 600x300x100mm with a 3" Inlet tank and 2.75" outlet tank. Please note that the 2.75" tank was initially 3" but i got it replaced to 2.75" to suit the VSPL piping kit. In the process of replacing the 3" tank to 2.75", i made it clear to the alloy welder that the genuine Trust tanks are not to be tampered with. Hence, the alloy welder had only replaced the section housing the outlet pipe, both inlet and outlet still have the genuine Trust tanks :)
Price: $550 ONO OR STRAIGHT SWAP FOR A 76/80mm CORE!!
PM or post up any further enquiries :)
Thanks in advance,
nuR
Edited by nuR.spec
https://www.sau.com.au/forums/topic/97894-trust-rspl-intercooler/
  • 4 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
