All the SCOOP on SWOOP!!!!
  • Replies 143
Guest Austin Powers
Hey Jimbo, I'm thinking about getting a gemini for $500. Do you think Prosperion will approve me. I have good financial record. Here is my credit history for your financier to evaluate.
1. in 1992, I borrowed $5 from my sister and paid her back 2 weeks later.
2. Austudy busted me for not living away from home so I paid back my away from home allowance in 5 years plus interest.
3. I took $2 from a begger in the street but gave $5 to the church the following month.
4. Me mum still owes me $25, so in terms of net value, I'm worth $25. (shit, I forgot, I still owe my dad $50, so that puts me in negative)
That is an awesome credit record dude. I have no debt and I paid back everything I take. :)
1. in 1992, I borred $5 from my sister and paid her back 2 weeks later.
2. Austudy busted me for not living away from home so I paid back my away from home allowance in 5 years.
3. I took $2 from a begger in the street but gave $5 to church the following month.
That is an awesome credit record do. I have no debt and I paid back everything I take. :)
I think you should just stick to your fullee sick echo :uh-huh:
:bahaha:
Yes Dr...but if pain persist, can should I come see you?
Ed, you on de dole and you driving an R34.....and cops fly.
Dr, what you do? Speaking of sugar, I'm at work at de moment sipping my tea with 3 sugars. It's gud shit.:)
you obviously haven't been to centre link before :)
:bahaha:
Guest Austin Powers
you don't scare me off that easy. I'll take you on and your biceps...SWOOP might envy them but I have my chopsticks to defend myself. LOL.
But anal, that is something i would be scared off. I aint pushing no shit up stream man or no one is pushing my shit up the chocolate runway.
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
