Item: 1993 R32 RB20DE manual
Item Condition: good
Reason for Selling: time for something new
Price and Payment Conditions: 7,500 as is
Extra Info: Have had car for over a year and a bit, engine has always run excellent and been extremely reliable. It has only really ever been used as a commuter to and from work etc.
With all the P plater laws coming in this is the perfect car for you guys who still want a skyline but can't have a turbo one. I guess alternativly it would be good for a turbo transplant but i dont have the time or skills to do it myself. Saying that i wouldnt undestitmate the fun you can have in a non turbo...at the end of the day its a skyline that goes great.
- description-
side skirts
type b rear spoiler
gunmetal grey paint in great condition
12 inch subwoofer (panasonic)
4 channel amplifier
new tie rod ends
rear 6 by 9 clairon speakers
Headunit with picture display (panasonic)
3 inch cat back exhaust
Momo race steering wheel
Trust gear knob
Heavy duty clutch
SR silvia wheels
New rear tyres and good fronts
blue dash lights
valuer (dont know how to spell it?) cloth interior. Same as GTR's
better than the usual grandpa style
159 xxx k's on the clock
plenty of rego
timing belt changed at 100 000k's (100,000k service)
new steering bushes and arms
damper control struts all around
lowered springs
Limited Slip Diff
Once again it is very rare for a non-turbo to have a LSD. This car has plenty of susprises most likely because it is a very late model R32 and is a series J. This car has been serviced every 10,000k's and sheded every night. Umm to be honest there are a few scratch marks on the car mostly around the key hole....(all these were on the car before i owned it) and a few cracks in side skirts. All easy to fix with a bit of touch up.
Contact Details: email me at - [email protected]
Edited by gunmetalgrey
https://www.sau.com.au/forums/topic/98547-1993-r32-rb20de-manual/
  • 4 months later...
  • 3 months later...
  • 1 month later...
  • 2 months later...
  • 10 months later...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
