I have a set of stainless steel front pipes from an R33 GTR, which should also fit an R32 GTR. Twin 2.5" pipes to single 3" pipe. Was bought brand new from Hi-Tech mufflers and only used for a few months .
$300 (These retail for $450 new.) SOLD
Also have an X-Force stainless steel cat. back system. 3" pipe to the middle muffler then 3.5" pipe to the rear muffler. Canon style muffler.
$490 (These ratail for $850 new)
Item: R33 GTR stainless steel front pipes and cat. back exhaust
Item Condition: Excellent condition, like new
Reason for Selling: Dont need them anymore
Price and Payment Conditions: Cash or direct deposit. Can pick up from Sydney or will post interstate if buyer pays for postage.
Extra info: Can do a chaeper price if both front pipes and cat. back are bought together
Contact Details: PM me with any questions or if your require any pictures.
Edited by GTR333
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
