Hello,
I have just got my 34 back from its first major service since I picked it up($800!)
When I start the engine, the revs go to 1000 and then drops and stalls, all this in about 1 sec. It is an Auto (Tiptronic) I also have aircon issues which I think is the compressor. the stalling happens with the aircon on and off so I dont think it is related.
https://www.sau.com.au/forums/topic/98910-stalling-engine/
Thanks! It was a gimmie that I was takening it back, just didnt want them to pull my pants down about it.
There was a conection that goes to the top right hand side of the engie block that wasnt in fully, that has fixed the stalling problem as well as the aircon noise.
New problem now! (Yes still taking it back - AGAIN!) Every time I stop, a huge vibration/pulse shakes the engine and teh whole car, revs dont drop, it is almost like the engine is throbbing, it aslo occurs on occasion when driving at low speed but mainly at the lights.
An another note, I used to get arroubd 450+ k's out of a tank, since this service (Ingector rails cleaned, throttle body clean, Iridium s/plugs, oil fluch ECT...) Fuel consumption is 350k's WTF??
It is going back but wanted a second option as I dont like being a boomerang!
Any advise/opions?
Thanks Guys
Daz
https://www.sau.com.au/forums/topic/98910-stalling-engine/#findComment-1808421
I cant help you with the throbbing engine thing but the fuel economy thing... give it a few more tanks before you judge it. Make sure you reset the ECU by removing the battery lead thingos for a few minutes. See if that does the trick.
https://www.sau.com.au/forums/topic/98910-stalling-engine/#findComment-1809001
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
