Hey all !
I have been looking at this conversion and remember seeing somewhere that there are heaps of these conversions in Thailand and Malaysia n stuff. But I cant find any tech info !  :P
Can someone link me up or provide some info ?
Thanks all.
I have a cef with the conversion in Thailand. It's an auto and can really move. It's is also tail happy. Slides at the light, out of parking lots, doing u-turns... fun to drive. I've been told it's one of the cleanest conversion my friends have seen there. They have this engine in everything, Benzs, BMWs, Volvlos, 180sx, Everything.
But it is front heavy, which might be why it's so tail happy. I never floored it before too. The crossmember is drilled to hold the engine mounts. To my understanding the tranny is Toyota, and the drive shaft is weilded to the cut ceffy drive shaft. I can't confirm this becuse I'm currently in the States and have never had the car on a lift yet. Northern Thailand doesn't have to many large autoshop. Roads aren't that good either. The cat converter hits everything out there. Atleast I hope it the cat and not the oil pan. I even took out the cut springs it came with and put stock height springs, and it still hits once and a while. In additon there is a lump on the passenger side floor next to the gear shift. Don't if that is mod from the installer to have the exhuast still exit out the left. Dunno.
With all the possiblities of the 1JZ, it sit too low for me, and the idea of the weilded drive shaft doesn't sound like a good idea if I wanted to build up the motor. But if you are looking to drag with it, it might be alright. Most of the drag ceffys in Thailand are running the 1JZ or 2JZs.
As for me I was thinking of getting the an SR20, RB25, or RB26 swap instead. Been waiting to post about it. So what engine do you guys perfer for a drift setup? SR for lighter car, but was leaning toward the RB25 for more power. What do you think?
PS keep the good info coming on the forum. It's so hard to find info on the Cefiro, and my Thai is crap. This the only place I can read. :( Thanks.
Edited by shinji_eva
you have a 1jz but considering an RB25 for more power?
i guess you just need to do some research mate, the 1jz is regarded as one of the best straight 6's on the market, can make an easy 300 rwkw + with stock bottom end, possibly more with good tuning!
Yeah I've seen the giant T88 turbos in Thailand, and know of the potential of 1JZs. But I was actually thinking of having the car setup for going sideways rather than straight. :P
grass is always greener on the other side... RB engines are harder to get and more expensive to buy/mod than 1JZ's over there, wheras here its the other way around.
SR20 definitely for weight reduction.
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
