Hey all !
I have been looking at this conversion and remember seeing somewhere that there are heaps of these conversions in Thailand and Malaysia n stuff. But I cant find any tech info !  :P
Can someone link me up or provide some info ?
Thanks all.
I have a cef with the conversion in Thailand. It's an auto and can really move. It's is also tail happy. Slides at the light, out of parking lots, doing u-turns... fun to drive. I've been told it's one of the cleanest conversion my friends have seen there. They have this engine in everything, Benzs, BMWs, Volvlos, 180sx, Everything.
But it is front heavy, which might be why it's so tail happy. I never floored it before too. The crossmember is drilled to hold the engine mounts. To my understanding the tranny is Toyota, and the drive shaft is weilded to the cut ceffy drive shaft. I can't confirm this becuse I'm currently in the States and have never had the car on a lift yet. Northern Thailand doesn't have to many large autoshop. Roads aren't that good either. The cat converter hits everything out there. Atleast I hope it the cat and not the oil pan. I even took out the cut springs it came with and put stock height springs, and it still hits once and a while. In additon there is a lump on the passenger side floor next to the gear shift. Don't if that is mod from the installer to have the exhuast still exit out the left. Dunno.
With all the possiblities of the 1JZ, it sit too low for me, and the idea of the weilded drive shaft doesn't sound like a good idea if I wanted to build up the motor. But if you are looking to drag with it, it might be alright. Most of the drag ceffys in Thailand are running the 1JZ or 2JZs.
As for me I was thinking of getting the an SR20, RB25, or RB26 swap instead. Been waiting to post about it. So what engine do you guys perfer for a drift setup? SR for lighter car, but was leaning toward the RB25 for more power. What do you think?
PS keep the good info coming on the forum. It's so hard to find info on the Cefiro, and my Thai is crap. This the only place I can read. :( Thanks.
Edited by shinji_eva
you have a 1jz but considering an RB25 for more power?
i guess you just need to do some research mate, the 1jz is regarded as one of the best straight 6's on the market, can make an easy 300 rwkw + with stock bottom end, possibly more with good tuning!
Yeah I've seen the giant T88 turbos in Thailand, and know of the potential of 1JZs. But I was actually thinking of having the car setup for going sideways rather than straight. :P
grass is always greener on the other side... RB engines are harder to get and more expensive to buy/mod than 1JZ's over there, wheras here its the other way around.
SR20 definitely for weight reduction.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
