If you're serious about sport photography, then do consider the 20D, because its burst mode is 5fps, where as the 350D is only 3fps.
I planning to take martial arts photos, and within that split second, there's a huge diference between 5fps vs 3fps !!
yeah thats cool.
I just checked the quote i got there and it was for the 20D not the 350D.
The guy at the shop got me talking to one of the sports photograhers down here and he uses the 20D and or the 5D for his work.
SO might look at going down the road when i save a little more $$$'s :D
Cheers B
  • Replies 83
Posted Images
lol, you dont need burst mode for sports photography if you're any good
Yeah thats also what i was recommended from the guy at the camera shop as he said it would be easy while starting out.
Or he just wanted to sell me a more expensive camera :lol:
Well seeing as im not any good im sure i will need it to start :)
Hehehe I must be getting old .. cause I cant seem to take a photo of a hit to the head during a sparring competition.
Seriously, it's like taking photo of a boxing match. Trying to capture a hit to the head is almost imposibe, because even at 5fps is too slow. Might even need 8fps .. of course this doesn't apply to many sport .. because the contact time is so short...
train yourself not to use it
I will try Obi one
I can see your point with boxing and martial arts and i think its similar with motorsport, but i would love to be able not to rely on burts mode to get the shot!!!!
timing.
its better to take a few good shots when the moment is right, rather than 10000 shots where 90% of them are crap
timing.
having said that, do you think im better off waiting till i have enough to buy a 350D or 20D with the Sigma 70-300 lens or get a cheaper film SLR for about $400-600 and start with that???
Taking into consideration im starting out with photography and know about as much as i do about ballet, FARK ALL :lol:
Cheers GMB
Cheers GMB
the 350d has 95% of the features the 20d has, i dont really a see a point in you going for the 20d other than for the sake of it
so other than the menu set features/set up and the shutter speed there isn't really a huge difference between the do, just price tag???
Sorry for another dumb noob question
but when im looking at camera's online from places like Ebay what does it mean when it say's thre not a REBEL or REBEL XT???
What price should i look at spending on a new 350D and when im looking at getting a memory card would a couple of 1GB cards be fine and is there a brand that i should look for with advantages over the others? EG: read/write speeds
Cheers B
Canon Digital Rebel = 300D
Canon Digital Rebel XT = 350D
as for memory cards
kingston and sandisk are both good, and they both have their ranges of high speed cards
get a 1gb or 2gb card
Cheers darK
timing.
Hey, I would be extremely happy to have a 10% success rate :)
Hehehe .. OK, how about a challenge :) ?? Can I get you to go and take a photo of a pigeon in flight in manual mode .. try to time it at full wing span :) .. See how 'good' your timing is :) .. I'm just darn too slow .. and prefer to depend on a 5-8fps camera, if I want to take photos of fast moving object.
d-d have you had a chance to use it yet and if so what do you think for a beginner???
I'll have it in about 2 weeks. Ill PM you then :)
Correct. However, i think the American version of the 350D is called the Rebel XT. Whereas the Australian version is just the '350D'.
So maybe there is a slight difference between the Rebel XT 350D and the Aussie 350D. Was what i found from readings...
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
