I dont think he said he wanted to get 200kw, just wants to know if he can run the 3 mods on a stock ecu id be interested to know also as im interested in a smilar set up.
Edited by R33_Series2Lover
At this present time yeh im pretty much wondering if it is ok to run the exhaust,fmic and panel filter comfortably and safetly most importantly on the factory computer alone . Good to see im not the only one :P
Here's my input: I think you and R33_Series2lover are the same person. Are you? You have the same car, ask the same questions, and write in the same style. :huh:
i wouldnt even worry about the front mount. When I had my r33 all i had was full exhaust/ cat, safc and 11psi.
And there were no problems at all. In my opinion youd be wasting your money buying one if your not going to go crazy with mods.
yer, if u arnet going to fiddle with the boost (i dont know why you wouldnt though) dont waste your money on a fmic as they arent needed
turning up the boost doesnt hurt anything though, and gets you better gains than most other mods, so im unsure why you are so against doing this
even with the standard ecu, it can handle extra boost
Ahhh no im not pretending to be someone else. I give you points for creative thought and actually spending the time to work something like that out. Impressive............ anywayssssss yeh well fmic would be for looks mostly as they look awesome. I dont take my car out to race tracks or the drag strip so yeh i have a good idea of how i want my car to look like and perform and this set up would do nicely.
In theory a bit more boost should make it to the engine with the aftermarket core?? I remember reading that the stock cooler looses around 3 psi across the core so if the after market one looses only 1 psi does this mean effectively you have upped the boost by 2psi as more is making it past the core?? Not sure on this and was wanting to know if this logic rings true :)
To put it as simple as i can.
It sounds like your mechanic is switched on and you should be able to trust what he says.
Everything he has said so far makes perfect common sense in modifying your R33.
I like that he has recommended a high flow panel filter rather then a crappy pod filter, and also the point that he makes about aftermarket BOV stuffing up the air flow meter signal is also correct.
Listen to your mechanic, have a read around these forums and you will not go wrong.
I'm with RB30... your mechanic sounds like a sensible and safe guy to listen to.
I have a series 2 R33 also, and i've got a K&N filter in the airbox.
I didn't want to start hacking front bars or anything like that, so I have bought an R34GTT cooler (plenty for sale on SAU). I'm yet to fit it, but they do flow better, are a little thicker, and have bigger inlet/outlets on the end-tanks. ARC make a SMIC (stock mount) intercooler which is made from aluminium, and is supposed to be several kilo's lighter than the original. The stock R34's make 206kw... so I figure that its intercooler is good for at least that much.
My next move after fitting that cooler is to get a CESRacing split dump pipe, then source an 80mm cat, and order an exhaust.
I'm quite tempted to dyno my car before and after to show the differences using a panel filter, R34 cooler, 3" exhaust... but it costs more money! =-[
Edited by RANDY
    • Yea I mean I know it exists, but finding (specifically) female BSPT to male NPT (i.e, to plug a Nissan OEM sensor into a 'standard' NPT port) was truly difficult. I don't think I'll recreate the setup I had in the past unless it's (possibly?) advisable with a stronger T piece made of steel, but who knows if the aluminium threads in the block become the next weak point etc. Given it may need to be redrilled out and something tapped into it, it'll need to be Female BSPT to the something that ends uo coming out of the side of the block.
    • Sounds like a perfect time to harness up a couple of the dogs, show the horses what real power is about!
    • And I'm guessing my GTR might be feeling a bit unloved. Had to push it out to get the R33 out, but couldn't push it back in (its a bit uphill,  haven't got around to installing that winch yet, and Kel complains that its "too hard" to help push cars uphill after her double back surgery....kids these days) Hopefully I can get that winch mounted and get her back inside before a pine tree falls on her in the storms coming this week.
    • Yea all the cars run 295 cause f**k having different sizes
    • So, this happened today r33.mp4 No, I don't have much of a future on tic tac Yes, it needs a tune Yes, I cut the video just before I stalled it ....gotta be nice to fresh engine.
