  • Replies 116
Hey mate,
I pm'd you in regards to a airbox will take one of the complete aloy ones if you have one ready i need it immediately please pm with details. Will this cover a rather large trust pod filter.
Regards,
Daniel
Unfortunately after a whole night of umming and arring... I am saddened to say that this box will not fit the R34GTT :) Main culprit preventing this is the radiator overflow bottle which is in the way big time.
I really can't be bothered hacking away at this thing to make it fit as I'm quite sure the finish would not be satisfactory. I'll just make up my own box ~ I will however comment on the quality of this item by Mr_Crust, excellent value for money in my opinion!
Anyways, if any of you guys are in need of one for the R33, I have one available (clear top in polycarbonate). Only one available as I no longer need it, contact if interested. All other enquiries to Mr_Crust please :D
Guys, if anyone is after one of these boxes for an R33 (w/ clear polycarbonate lid), please let me know.
I purchased mine earlier this week from mr crust, but unfortunately it doesn't fit properly on my car as I have a new turbo and the hose to the afm isn't as long as the std item which means the pod doesn't sit fully within the box. I don't really want to fork out extra cash to replace a perfectly fine hose (I only did the upgrade a few months ago), so it's available if someone would like to purchase it.
I will also comment that the quality of this product is well worth the money in my opinion. I'm just dissapointed that I couldn't get it to fit! :D
Anyway, I'm located in Sydney, please PM me if you're interested. All other enquiries to mr crust :D
I will also comment that the quality of this product is well worth the money in my opinion. I'm just dissapointed that I couldn't get it to fit! :iluvff:
Anyway, I'm located in Sydney, please PM me if you're interested. All other enquiries to mr crust :(
Bump - need to sell :P
  • 3 weeks later...
OK guys, as it stands at the moment ive got 4x clear air boxes made and 1x aliminium, this will be the last of them. So if you have any intrest just PM me or post it up in this thread.
price is still $120 which includes the delievery via express post
  • 4 weeks later...
nemz: sorry mate, i have nothing to suit an r32.
habibz_r33: i will Pm once i sort a few of these orders out.
as for all the PMs i have replied..
Edited by mr_crust
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
