  • Replies 116
MY33RT : PM Sent
5ky: Of the top of my head i think they are 1.1mm thick , but i will check tonight to be 100% sure.
These are done the old fashion way, all by hand, no metal fabrication shops get their hands on them.
  • 1 month later...
  • 1 month later...
  • 3 months later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
