  • Replies 318
HOME!!!
A great night had by all.... especially considering the thread started out as a question :D Thoroughly enjoyed catching up to all of ya on the F3 pushing the speed limit all the way :)
Maisys was good :D That's for all those who piked after the F3...
What a way to wrap up the 2005 Skyline Calendar :D Well done to everyone who rocked up, and thanks for all making it a good night.
EDIT: Dang I still wished I saw that shower scene!
Great night guys, nice to meet a few more peeps
On the way home at chatswood just after Liz and Rukus turned off there was a massive accident on the Pacific highway - looked like a car crossed the median strip into on coming traffic
It was madddddddddddd!
I was in steve's 32 GTR and it was aweseome!.
Love that drag we had with that umm 4wd car.. :P
Shaun said it was a VW Toureg (he thinks its the fastest production 4WD, although the porsche cayenne must be close)
- 700nm torque, not that that helped him............ :D
whens the next cruise stan that one was awesome!!
That's my question I believe... seriously someone else should put a cruise up; I think it's about time I hung my cruise-whoring gloves on the wall :D
code name "Nur Spec"
That wouldn't be my R34 Nur Spec would it Ruk?
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
