hey guys im in a bit of a jam....cracked the plastic at the back that says skyline......u know that long plastic thing in between the indicators......its the clear one with the skyline in silver not the painted one......does anyone know of a wrecker in the S.E suburbs that has some skyline parts.........this part in particular.
thanks in advance
https://www.sau.com.au/forums/topic/10020-wreckers-in-se/
Originally posted by scorp
Two that I know off.... Benett St Dandenong (opposite Repco) and another cnr Hazel Av & Dandenong St, Dand. .... don't know the name of them though :confused:  But give them a go.
hmm preety close to where i live!
do they have full wrecked skylines or just spare parts?
https://www.sau.com.au/forums/topic/10020-wreckers-in-se/#findComment-156296
just came back from visitin both.........renew on benett wanted 250 smackaroo for it.....pffft.....yeah rite.....they are more like a car yard dealership thingy......im sure they can source u any part most likely for the most expensive price:grins: as for the other place...it is more like a small importer.....nice factory too...hehe...yeah he wanted 130 for it....250-130??.....wtf? he was determining the price with his partner...obviously not in english but i could understand.....keke....so im sure i could get it cheaper .........last resort ill probably go back to these guys as it is the cheapest so far. thanks again scorp and skylnr!!
https://www.sau.com.au/forums/topic/10020-wreckers-in-se/#findComment-156463
Victorian wreckers are a ****in rip off. I was after a pair the front bar standard indicator assy (the ones without the fog lamps). A certain wrecker (Just Jap in Thomastown) wanted $150 each for second hand items. I ended up buying brand new ones from a NISSAN dealership for $75 each, same day pick-up (ordered them at 8:30am, picked them up at 3:30pm).
Moral of the story; Check at dealerships first, to find out new price, then go to these w****ers.
https://www.sau.com.au/forums/topic/10020-wreckers-in-se/#findComment-158241
came across two new wreckers today......tokyo spare parts on future rd kesborough...they deal with front cuts/off cuts....saw a silver r33 front cut outside...and the other is new fujimi or something like that....just around the corner, alot of imported secont hand parts. have a look in the new S.E yellow pages for the exact address because i cant be stuffed...hehe
https://www.sau.com.au/forums/topic/10020-wreckers-in-se/#findComment-161626
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
