Having owned both cars myself.....
Very true that the 300 are hard to work on, however stock 3L manual do go very well. Few mods and you will have a fair bit of power for a NA. More so, the 300 engine for some reason seem to need more work...what I mean is that a lot of things get dirty, old, corroded and need maintenance. It seemed like I had to clean every little plug in the engine bay!! IMO the 300 look hot. My old 300 had exhaust, air filter and bit of engine work and it would keep up with a few v8 and give turbos a bit of a run!
However at the end of the day it is up to you, what you can afford, what you like better and also, what you can find because there is so much cr#p out there due to both of these cars being old!
If you upgrade to a TT 300 you will never look back. With basic mods the power is amazing! My second 300 was a TT and it use to eat skylines! However, maintenance on the TT is expensive and these days i prefer the 32, especially the interior!!!!
My 2 cents
Cheers
  • Replies 45
get an NA r33 series 2, i got one in may and payed 12,200 so prices carnt be that bad.
it had done 80,000k's and was in mint condition. =) (NOT ANYMORE!)
f**k the 300, to much to run. heavy + larger motor will mess with your funds
in my mind there is no comparison to an 89-91 model car and a 96....i dont think you would be able to pick up a 92+ model as they are alot more sort after. but who knows
300's are getting a bit old now and as mentioned in other posts, the engine is a nightmare to work on. Being an older car, there will be SOMETHING that will need replacing/maintenance in the engine bay and it's going to give you headaches.
Depending on your budget, I think the later the model of car you can buy the better. I don't like R33's much myself but if you could pick up an N/A series 2 R33 it would be your best bet. The later the model the better.
Second choice would be an R32 GTS25 (RB25DE) but once again they're getting a bit old so be prepared to fix a few things. Plus side is theyre usually easy as pie to work on, so it wont cost you as much.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
