gday guys and gals.
my front left makes a ticking noise to which i initially put it to a screw in the tyre. tested this theory by putting my stockie back on and the noise dissapeared. drove around with the screw for a while and just got around to removing it the other day. problem is i still have that ticking noise on rough roads and whenver i turn right. im now suspecting it could be the wheel bearing. does anyone know how to test it to see if its stuffed?? or could it be something else
cheers.
https://www.sau.com.au/forums/topic/100544-stuffed-wheel-bearing/
Jack the car up, spin the wheel and listen for the noise.
Then remove the wheel and check the hub for up/down play.
Mine made more of a rubbing noise when it was shot (as water had gotten in past the seal). It had no play though.
You can get a new bearing from nissan for not much at all. You will need to get the old one pressed out and the new one installed. I can't give you a definate price as i removed the hub myself and had a mate press the bearing out and install the new one for nothing then reinstalled the hub myself.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
