they arer legal as long as u dont go over 6000K, anything below is ok.
My r34 GTT has HID in it, im looking to upgrade to those 8000K or somethin higher, cept the price and the illegal part scares me off.
Edited by Silver_R34_GT-T
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1843564
hi guys
as far as i know they are still not legal as they are non adjustable!!! Wierd cause an r34 GTR head lights are adjustable yet you still have to take them off to get them complianced another contradiction in QLD Transport rulings.
cheers
they need to be self leveling and have washers to be compliant,interior adjuster for load is not enough,if 34`s had same set up as honda,bmw,volvo etc ...self leveling device in boot and h/light washers they would comply.Thats ADR rules.. nothing to do with qld transport really,not sure if they would know difference between self leveling and non adjustable though once the car is registered: :(
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1843609
can someone explain to me what self leveling n have washers mean??
does it mean the bulbs move as the car goes up or down a hill. n also the bulbs wash themselves? wtf?
if you ever noticed oncoming bmw etc you will see xenon h/lights "changing colour" type thing as they approach...this is lamp adjusting to roadsurface ..leveling,
the washers are the same as windscreen washers but mounted in bar and face the h/lights for cleaning
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1844893
ahh ok, but y do HID need the washers and normal lights dont?
Correct me if i'm wrong but this was what i was told, when headlamps equipped with HID are dirty they do not give out as much light hence poorer visibility, compared to normal halogens.
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1845719
humm thats not really correct.. the plastic lens / glass gets discoloured because people use high temperature globes / cheap hid's that dont have UV cut in them.. hense the discolouration... you can polish 80% of it out using meguires plastic X polish and cleaner.or brasso if you have the time.. . i have hid in my 33 both of them gtr n gtst .. ones 6500K the other is 8000K have been pulled over many times but they never mentioned the light ,im not saying they are legal.. depends on cops decresion
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1849624
thx for all reply and suggestion! as you guys already know that the HID is very bright light specially at the night (skyline + HID = eyes catcher ), so I have a little bit worries after I put the HID in my car, the cops will always say "hi" to me on the road.... :(
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1854298
We sell GE HIDs to many companies and have never had a problem with Legality.
Officially, ADR requires Auto leveling and headlamp washers fitted for HIDs.
Auto leveling adjusts the level of headlight depending on number of passengers (as passengers at the back lifts the front of the car). They do not level as the car drives along. They reason why BMWs change colour is due to the projector they use. (its like a rainbow effect, light coming from the side of the projector has the shortest wave length hence blue)
Washers are used to keep headlight free from ice. As you can imaging, snow and ice and reflect alot of light and this can cause HIDs to be "glary".
ADRs regarding HIDs are copied directly from the european ECE 37 regulations. In Europe, some counties do have lots of snow and hence the washers, however, they are useless in most parts of Australia.
In US and JAP, HIDs don't need to be self leveling or washers. However, this is soon to change.
https://www.sau.com.au/forums/topic/100928-hid/#findComment-1867116
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
