  • Replies 71
If we need a minimum of 6 cars, and this is a "bling" event, id suggest that we first use the sort of skylines that Autosalon aims at ("blinging")
Ill have a new interior by then also, its white suede with grey leather
Cant be hard to get 6 good looking skylines
Would also be good to get a variety, R32 R33 R34 gtst's and gtrs
Either way, im in
Either way, im in
Not a bad idea....
but poor Mr Stagea :O
Hey Jago. just a quick question. How long is that inlet system you have?is that custom?
everything is custom mate, no kits for the 31, for anything really (or are hard to come by and expensive)
As for autosalon, i wouldn't mind goin, just gotta fix up some paint tho, it aint 100% show grade but hey, it's different
Where have you been @ phil.
Whats going on with the car.
yea i just been here and there mate, haven't seen you around much either :(
As for the car, just came out of the workshop, fixing a heater hose, which caused major overheating. High pressure hose power steering leak, screwed sump plug, fitted bigger injectors, upped the boost and dyno tuned the microtech. Ran 182rwkw on the autosport engineering dyno @ 13psi, peak power at 7000rpm ;)
What bout u man? or u keep her the same? nice lookin 33 i must say
Man this seems to be getting serious... Definitely count ME in!!!!!!!
After all.. I'm probably teh biggest RICER in here...
BLING.. check
PAINTWORK.. check
LED underbody and interior.. check
AND
NO IMPULS.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
