  • Replies 71
If we need a minimum of 6 cars, and this is a "bling" event, id suggest that we first use the sort of skylines that Autosalon aims at ("blinging")
Ill have a new interior by then also, its white suede with grey leather
Cant be hard to get 6 good looking skylines
Would also be good to get a variety, R32 R33 R34 gtst's and gtrs
Either way, im in
Either way, im in
Not a bad idea....
but poor Mr Stagea :O
Hey Jago. just a quick question. How long is that inlet system you have?is that custom?
everything is custom mate, no kits for the 31, for anything really (or are hard to come by and expensive)
As for autosalon, i wouldn't mind goin, just gotta fix up some paint tho, it aint 100% show grade but hey, it's different
Where have you been @ phil.
Whats going on with the car.
yea i just been here and there mate, haven't seen you around much either :(
As for the car, just came out of the workshop, fixing a heater hose, which caused major overheating. High pressure hose power steering leak, screwed sump plug, fitted bigger injectors, upped the boost and dyno tuned the microtech. Ran 182rwkw on the autosport engineering dyno @ 13psi, peak power at 7000rpm ;)
What bout u man? or u keep her the same? nice lookin 33 i must say
Man this seems to be getting serious... Definitely count ME in!!!!!!!
After all.. I'm probably teh biggest RICER in here...
BLING.. check
PAINTWORK.. check
LED underbody and interior.. check
AND
NO IMPULS.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
    • This is the only point I can access with any floor jack and my car is SUV height - What's the actual suggested alternative here? I have also driven up on blocks in the past, but lets say you have a problem and the car is on it's wheels already and can't be driven up/off anything? Not a huge fan of bits of wood being spat in random locations either (it hasn't happened, but what-ifs occur) Perhaps I would also really enjoy having a quickjack :p Time to google quickjacks.
    • The wires look to be a healthy gauge, more than I would think the pump needs. I guess another concern is if the FPCM will be happy with the extra current draw. I have heard they are a bit sensitive.
    • It will be fine. The real question is whether the existing wiring is fat enough for the current drawn by the bigger pump. The 342 is not that hungry, but it will be well worth pointing an IR pyrometer, or even better, a thermal camera, at the pump hat wiring when it is running, just to make sure. Or, you know, just touch it to see how hot it is.
    • Hi guys, Sorry to revive such an old post! The fuel pump in my M35 has finally given up, the car has been sitting for 3 years so I'm not surprised. I bought a Walbro GSS342 of Scotty some time ago, so I'll throw that one in. My question is, if my car has no performance mods at all, do I need really to mod the wiring to supply constant 12V? or will the new pump be just fine at the reduced voltage at idle? Thanks guys..
