I could turn the boost down, fuel pressure, back the timing off. You could have all the comforts of an almost stock 32....cept the 100db out the exhaust lol
You gotta take me for a spin when its fully tuned lol, it'll be awesome.
oh by the way, is that gonna be the name of your shop in your sig?
For sure...and yes, that's the name I am now using. Probably won't have an actual workshop for about a year, maybe sooner but getting all the paperwork sorted first and seeing how much business I can drum up.
First point of business when I open up the workshop will be to build a drift car with the 25/30. Just need to find a driver crazy enough to do the job for Drift Nationals.
Edited by 3lit3 32
So in short, the auto isn't a direct comparison but i'll definitely take you up on your offer when ever it is convienient for you as the goldy is only a hope skip and a jump
P.S. no probs on the PM, appreciate you posting :P
Edited by ellie
Pretty sweet name there Dan and actually surprising no one had snapped it up before! By all accounts you do good work with much praise so PROPS DOG :P
Edited by ellie
Hrm, i've got a bit of a proposition for you, Dan, will chat to you about it this afternoon :blink:
Ellie, here is a link to the specs of my car... i'm expecting probably around 170 - 180rwkw after the tune on the 21st, and i could probably take you for a bit of a drive so you get a feel for it.... PM Me if you're interested...
http://www.oznissan.com/board/index.php?showtopic=2
Thanks to everyone that posted to make my plea of a thread a success. Your genorousity gives me a warm fuzzy feeling :P
Extra thanks go to Terry, Dan, Gordon and Jason for offering your time and hardware and being all round good sports. Jolly good show old chaps, pip pip and all that!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
