but that was not the question....
you are correct though...a street/drag/circuit GTR is great with 2x HKS 2530's
its the best all round turbo for the RB26...
this is only my opinion...
My opinion too.
Since he already has all the stuff for GTSS's, the 2530's was an easy answer.
:O cheers :)
Edited by Sydneykid
the power the t04z is gonna make (potentially) is gonna go past the stock rods limits i would imagine (or didn you put betters ones in there Nick?)
Shouldnt be a problem if the rod bolts are replaced with something decent and your not revving the crap out of it. The achillies heel of the conrods isnt the rod itself but the bolts. Put a set of ARP bolts in, and you will be pretty hard pressed to bend them.
Nick what would you call your target rwhp or awkw etc ? as there might be other alternatives to your GT-SS HKS that will deliver better responce and drivable than something the size of a T04Z. I personally would only recommend a turbo that size if your chancing 440 to 450rwkw anything much under that i believe you can be better served with a different combo.
pete
Nick...I'm with Tommy. I hav compared the response of my car to one with a T04z with a 0.81 housing, and the GTRS's spool up a little earlier and make similar power at the same boost level. I know they are different cars and there are a lot of variables, but the bottom line is whether or not it is worth the hassle and expense of going for a single and external gate.
The big Tomei lowmounted twins are another option that would be interesting, or even a pair of Apexi turbines.
Hope this doesn't offend any of the twin guys, seems to me that the single turbo cars have ran the times at the drags
Whats anyone on this forum done time wise with GT-RS?
hows 10.38 from a smaller set of 2530hks grab you, name me a t04z that got close to that and on GT-RS i only know of one guy run them hard on the strip i believe he ran a 10 with them (it's hard to judge a combo on 1/4 times when nones really push them hard down there but i believe in the near future there a gtr that could change all that in wa)
the other little fact i would like to bring to people attention is
2530 rated at 640hp
t04z rated at ?800hp
efficience and ease of install lives with the twins as a bolt on combo
2530 rated at 640hp
What are the gtrs rated at?
And on the flip side name me a GT-RS GTR in Australia thats got close to that aswell?
Im 99% sure we will find the times ran from TO4Z and GT-RS are pretty much the same
That wasnt run on pump fuel was it? The cars been comprehensively stripped too hasnt it? So it doesnt really have anything to do with what Blitz is after...
I currently have HKS 2530's on mine and they have been awesome turbos, but to make those numbers you really do have to flog the shit out of them. The T04Z will make the alot easier at the end of the day (albeit though, probably a bit laggier).
Pretty much spot on there ;)
doesnt have track suspension, tis a car build with drag in mind
1475kg...is not what i would call comprehensively stripped...its only marginally lighter than a stocker....and I weigh 105kg.
with Nick in his car the weights would almost match.
we ran 28psi to do 10.38 and 10.36....redline was 8250rpm...changing at 8000. I dont think i have even come close to "flogging the shit" out of them yet.
35psi and 9250 is flogging the shit out of them.
what makes the car so quick is the almost instant torque the car generates off the line due to the 2530's midrange. The 1.4-1.5 60' are testament to this, to half track we are around 0.2-0.3 slower than Mark's 9.5 sec beast. The second half of the track is where the t04z would be superior, as the 2530 lack the airflow to have the topend for 9sec passes without the use of NOS.
contrary to popular belief, this car was never built with drag racing in mind. Our set-up is typical of a Japanese weekend circuit car. We run all the ultra hard suspension, off the shelf HKS Hyperdamper, Tein caster rods, JIC top arms, Hicas lock etc.
Stace took it drag racing to have some fun....it just got a little out of hand when the car began to produce some incredible times and numbers....the bug bit.
Edited by DiRTgarage
But then there is the no air cond, no power steeting, no clutch fan...
we run power steering...A/C is only activated when switched (so pulley free spins on cars with a/c installed)...but yes we run thermo's
and what about all the added weight from the cage etc ffs every one thing I've removed I know I've near added 2 for andra or the new set up
Unlike the Japs...we have rules to follow here with our drag cars which means added kg's...:)
anyhow...back on topic...
so Nick.....decided what TO4Z housing you will get?? .81 seems like the go.
im sorry, do disrespect for twins, :) but single is the shit. so long as the manifold is corect. none of this 40mm odd massive thick runners. sorry hks,trust im not reving it to 12grand!!
in terms of exaust housings. .84 splitpulse is the most versitile.(garrett)
for a comparison my old motor (26 with stuff) made 326rwkw on 16 psi.
and it was a. tw41.
or t04e with o trim turbine 60trim 14blade compwheel
.84 split rear .7 front cover.
1.25"id runners about 18inces long give or take.
full boost at 3600 in second.
lowmounts would struggle get that without the bottle.
besides they are laggy but not. (builds boost from low rpm but not full boost till quite late)
anyway nick my advice would be to go for a drive in one equiped with what u are thinking of doing.
just so you can see. and perhaps come to a compromise. cheeres.
:lol: :lol: :lol:
2530 rated at 640hp
umm. no ofence. 35psi boost and race fuel + a really good box. and somone who knows how to drive.
how longs a piece of string
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
