Item: Blaupunkt Acapulco MP3 Head Unit
Item Condition: As new in box, 2 months old
Reason for Selling: No longer needed
Price and Payment Conditions: Ebay Auction
Top Features
Decoding of MP3 Files
Radio
FM, AM
DigiCeiver
MW interference suppression
RDS
Digital selectivity enhancement (SHARX)
30 presets
CD
Playback of audio CDs/CD-ROMs
CD-RW-compatible
Disc Naming
CD mix
CD-Text
Disc Management System (DMS)
MP3/MP2 player
MP3 playback from CD-ROM
Display of up to 255 directories
Filename display
Display of ID3 tags up to 30 characters (V1)
Supports variable bit rates (8-320 kbit)
Mix
Amplifier
4 x 26 W RMS power
4 x 50 W Max. power
Digital parametric 5-band equaliser
AutomaticSound (GALA)
Source-specific sound adjustment
Auxiliary input
X-Bass
4-channel Preamp-Out (4 V)
Sub out
Sound Presets
Miscellaneous
Flip release panel
Display out (via opt. interface)
Clock
Telephone auto-muting
Pre-equipped for telephone/navigation speech output
MultiColour display (white+red+blue)
Night design blue
Front design in anthracite
Steering wheel remote control (special accessory)
IR remote control (special accessory)
https://www.sau.com.au/forums/topic/101239-blaupunkt-acapulco-mp3-headunit/
not sure how much i really want.... i was thinking $250ono but ill see how it goes on ebay i guess.
If anyone is interested in buying direct from me let me know and we can work something out.
Cheers
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
