Got my car back this afternoon from the mechanic. He didnt change the afm, basically gave it a check over, put it on the dyno, drove it round on the road a bit and said he couldnt fault it. Got it back on the highway and within 5 mins i had created a traffic jam! The problem is very easy to instigate, if i drive it gently and not on boost, all seems ok, if i give it some, say 1/2 bar or more, after i stop accelerating it basically looses all power, splutters, shudders i get very little response form the accelerator (if any) and if i fully remove my foot from the gas it will stall but i can keep it alive by pumping the accelerator, eventally it springs back into life as if nothing happeded. If i accelerate hard again same thing happens. Any ideas??
Cheers
This is freaky.... Same problem, same name as me (Andrew) same car! Mine spent 2 weeks at the mechanics (Although no progress was made)
and it refused to stuff up on them, so they couldnt diagnose the problem. It did it once, and from there they suspected AFMs. I won't go into my personal opinions of this place but basically they had a suspicion and just never ended up acting on it. I needed my car back after 2.5 weeks...so nothing was done. Car still does it. Any updates Twitchy? I'm really over this problem now! :)
ok guys, do a ecu diagnostic check, thatll tell you whats causing the problem.
mine said the afms were faulty so when i jiggled the afm plugs it work for a bit. so i fixed the afm plug wiring and it still didnt help.
so yesterday i open one of the afms and found the solder joints were all cracked.
they didnt looked cracked but when i removed the plug all the joints let loose!! 10 secs of soldering fixed the problem!
steve
Thanks for the help steve (im from fordlaser.com forums too, wrxtasy was my nick)
I forgot to add, that when the problem does strike the GTR, I can't rev past 2500 rpm... bounces off it like a rev limiter. Does this still sound like AFMs?
I'm searching through these forums compiling a list of similar problems that people have had, and hopefully the solutions they came to. I'll then show that to my mechanic so he has some idea of the situation.
BTW steve... relatively new to the GTR, how do I do an ECU diagnostic? Cheers.
Andrew
Also forgot to mention... we hooked up a fuel pressure gauge and I took it home for the weekend... no fuel pressure drop at all when the stuttering occured. I sure as hell hope its the AFMs!
Problem solved, after 3 bloody months of wondering.... Turned out to be the plug on the lower AFM wasnt even in properly. (Theyre vacuum sealed or something, meaning I couldnt feel it was loose until we took the upper afm off) Cleaned the terminals etc etc, and she's right as rain.
Edited by Sol32
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
