What a sad sad day it is today. Blown Turbo,
thats not sad thats f*kn awesome!!! Its the perfect excuse to wack a to4 on there, without being asked questions!! :O
though the pinched neck would suck l'd guess.
Edited by [ STAGEN ]
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851677
Hey Guys,
What a sad sad day it is today. Blown Turbo, pinched nerve in my neck  :O
Ok, so basically on a budget of $2000 what is my best and easiest option to get it back on the road again?
Cheers,
Chris
GCG ball bearing hi flow, very similar response to standard, up to 265 rwkw, more power EVERYWHERE on all 3 RB's I have fitted them to. Bolts back up exactly as it came off, no making stuff, buying extra bits, things that don't line up etc etc.
:) cheers :)
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851678
Yep new turbs is the best bet, youll prob need a bit over 2k to cover it with labour costs unless you are gonna put it in yourself. Check Nengun.com and get a direct bolt on kit like an HKS GT RS or you could buy another standard turbo for around $500 of these forums but thats no fun.
How did you blow you turbo? Too much boost??
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851715
what a mofo, eh AMS? Man that sucks big time. Bad luck to you, you've only just got it! That must really shite you off, but dont let it get you down.
$2k go the GCG hiflow. With the R34 GTT 'cooler you've got, some boost control & save up & do a SITC or similar and you'd end up with a top ride, with good power at a safe tune.
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851714
Running 10psi, but it was spiking to 12psi. Now they said that there is a boost cut at 12psi which when it hits that, it cuts the turbo, the constant spooling every 500rpm caused it to overheat. So there we go. Fun for all
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851732
Cheers Brendan. Does shit me off. But my neck is killing me. Something about a ciatic nerve? Anywho, just rang CGC then. They are going to give me a call back and we are going to discuss a sponsorship of some sort. Fingers crossed. Should be damn quick when I get it done though
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851735
Is that 10psi with standard intercooler?
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851743
bugger, a spate of blown turbo's is upon us. i've just done 160,000km, i wonder when mine is going to go. i've been running 10psi since i bought it (15mnth ago) but have an fmic, hope it doens't go soon, i'm saving for the manual, don't want to have to get a new turbo.
but AMS, good reason to get a better one, one less upgrade needed later
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1851795
When i got my FMIC and my vac lines were all screwed around, i was running 12psi with 14psi spikes.... damn the car pulled hard ...i loved lifting off boost :P
Anyway, its back to stock 7-8psi now, but to let everyone know, i picked up a screwed R33 GTST turbo for $150 delivered.... soon to be highflowed (after brakes and manual though :D)
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1853073
Damn so you didnt have any R&R Problems? :)
Yeah my car did go bloody hard though!
Ok, so im pretty sure I'm going ahead with the CGC Highflow. So when I get it on etc etc and the car is up and running. What boost levels should I have then? Just leave it at 10psi? Or go for more? (Will have Jaycar gear by then too :))
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1853336
Well, heres the deal
On 7psi the car is "fast". Then i have a 10psi map without a tune and the car is not as "fast". Then i had that 12psi/14psi map and the car was faster then "fast" without a tune. So maybe the total ammount of air was just overriding the R&R?
So these days, for daily i have it on 7. For drags on 7 and... yeh, 7 seems fastest.
Meh, I cant wait to upgrade the turbo and put the s**t back up there, with the pfc/manaul too - Alex=one happy chappy
https://www.sau.com.au/forums/topic/101343-blew-my-turbo/#findComment-1853610
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
