I am now offering for stupid low prices because i want the stuff out of my way.
PLEASE,PLEASE,PLEASE need to sell moving house need all stuff gone.
Gibson block RB20 never used $450 i paid $800
Tomie !.8mm head gasket in plastic still $230 i paid $450
RB20 Head good condition $150
I Think C's short shifter suit RB20 box $120
C'mon guys and girls make me an offer NOT a stupid one you never know.
Edited by mait32
interested in your head gasket. are you sure will suit the RB25? what will the compression ratio be at once installed?...and how much all up including delivery to sydney?
Tomie gasket brnd new not opened 1.8 mm will do what you want it to do, sorry bro i know i priced it at $300 but it has to be $390 i paid $550 and have an offer for $400 so price will be $400 delivered. Sorry about the f%c* around..
Edited by mait32
