Hey guys
I have an opportunity to buy a Grade A 93' GTST, 96kms with 18's and all for $10,500. There is however a catch, it is AUTO.
I am a huge performance fan and can not live without a manual, esp in a turbo jap car.
I was wondering if it were worth buying the car and doing a transmission Swap.
Has anyone done one of these before and seen the results?
I would really like to buy the car if the tranmission swap can be done properly. I have driven many silvia's that have been done and it is impossible to tell.
Any places in Melb which can carry this out and wat sorta figure would I be looking at.
Your help would be most appreciated.
Michael
https://www.sau.com.au/forums/topic/102285-manual-transmission-swap/
buy a manual for $3500 extra.. can be hard to track down the parts, and they can be expensive..
No you wouldn't be able to tell the difference (except on the firewall plate), but the conversion would probably be around $3000 anyhow.
$3000 Im assuming would include fitting as well?
Was wondering if there was a place that could do all the hunting down and convert it all for me...
Just trying to guage whether or not its worth buying the auto car.
Once AGain Im keen to hear of anyone who has actually experienced this conversion and the results they have seen, would be great
Cheers
It's a fairly straight forward swap. Tailshaft is the only thing that would need to be modded if you can't find a manual one. There are places doing rb20 -drive in drive out- swaps for as low as $1400. Sooo.. If rb20 manuals can be had for $300-$400 S/H.. I wouldn't be paying much more than $2500 for a rb25
Thanks for that. I wouldnt imagine the RB25 to be too much differernt.
Can you point me in the direction of any of these company's doing drive in drive out rb20 conversions for $1400.
If they do rb20's I dare say they would be capable to do an RB25.
If you could help me track a few down would be great.
Reagards
Michael
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
